7mm Churchill Halt and Sarsden Siding(s)
John TAYLOR
It seems from several sources that originally there was just a private siding and stopping place in 1897 and in 1906 the GWR took over and built a signal box and a standard height wooden platform with a corrugated waiting room.
Nearby was Churchill Mill and a private school which eventually purchased the Mill to improve access via the level crossing which up to that time was on Mill land.
The siding (Sarsden) as it was known then, was built as a loop and access was from a key on the train staff.
Goods traffic was agricultural, coal, milk and provisions for the school, and increased goods to and from the Mill.
A cart weighbridge and hut was built in 1913 and a crossing keepers cottage in 1930. A Port to Port express would also stop at the Halt if 24 hour notice was given.
Churchill Halt Sidings were extended during WW1 and a cattle dock was provided to give this project more operating potential..............
......... track is now down and the original catch point changed to a single slip. The cattle dock will be positioned at the front to help break up the rather mundane track plan.
Track is all C&L products and is laid to 32mm FS throughout. Locomotive operation will be DCC sound but everything else will be traditional wiring and switches.
wiring is now under way and hopefully completed by this weekend........
My intention is to model some of the more obvious point rodding and facing point locks and have chosen to use lost wax components from C&L.
In the meantime I have fabricated my favoured type of point operating system.......
I have used both types of tiebars provided in the C&L point kits.......
Once this is all complete all the action will be under the baseboard units ..............
John TAYLOR
Wiring of trackwork now complete, so time for some play............ got round to fitting sound to my Mogul and tried her out on the layout today. you can hear point motors in the background. They needed to be a low profile type as baseboards are not deep........
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
John TAYLOR
After thorough testing, the hinges needed strengthening and protecting from the power of the servo`s by
redesigning a `shock absorbing ` strip below baseboard......
Photo`s of the prototype at Sarsden Halt showed that pedestrians could cross the line via a pair of ` kissing gates`
So I have cobbled together these with limited photo info........
I think it will all come together with ballasting and painting, but that has to wait until I complete the rest of the six foot way....which will be the point rodding..........
John TAYLOR
Ow doo !!
Slow progress during the dark days of winter. Wiring and electrics for the track are still working well, so decided to finally say good bye to all my analogue controllers I set up some 20 years ago and convert my `control box`, which I designed to use on any layout I planned to build, over to just traditional control of points and signals with a basic mimic board for exhibition use.
Still need to apply labels etc...........
So thinking about 7mm trackwork and its appearance I think it important on a small project like this to add as much detailing of the permanent way as possible.
I ve cobbled together some ground signals from ABS and MSE kits...........
Ive added extra weight to make the counter balances work and these will be connected to the point actuating cranks using thread. Just got to figure out the painting without gumming up the movement!!!!!
Then it has been back to a bit of `playtime` so I took the lid off my Lionheart Pannier, removed all the gubbins and added a ZIMO decoder and a Youchoos pannier sound file.......
And so here goes..................
Wagonman
Lovely work but, just a thought... shouldn't the single slip actually be a double slip as otherwise the front siding is not trapped?
John TAYLOR
Hi Richard,
Thanks. Yes you are right..... I might make a cosmetic catch point for that front siding but there's going to be a small cattle dock there so it might not be noticed......... Making the single slip in finescale was a devil to get smooth running and I quit while I was ahead.......S7 would have been easier!!!!
