jamiepage
The resin coach sides are to all intents and purposes finished but the coach building continues. Do you mind an occasional update of progress? From a selfish perspective I must admit to finding 'show and telling' a good motivation to progress, but bit concerned the subject is a bit too far off beam.
Underframes are primarily of wood construction with prototypical steel flitch plates. Various brass detail attached, all glued and either pinned or bolted in place.
Opposing corner solebar/ headstock joints were Araldited with a strengthening angle yesterday, and have just done the same for the remaining two. Axleboxes had to first be milled out, to allow wheelsets to help maintain alignment. Stepboard brackets, spring assemblies etc all in place, so next will be remainder of underframing, brakegear etc. Axleboxes will have whitemetal cosmetic endplates which will camouflage the 'box/ spring gaps.
Actual springing will use piano wire for the outer axles, and probably just a weak coil spring on the centre.
I'll probably complete this frame to the point where it is stand alone, then assemble the other two I have bits for, before assembling
the bodies to fit.
the bodies to fit.
Will you be bringing it on Saturday? Im weakening
if it was GWR I would be sold
so I'm glad to see that you will be doing something. after going to all the trouble it seems a shame not to do it properly
really looking forward to seeing this
