The question of how to avoid paint / weathering getting between spring leaves and gumming up the action is one that I have asked of Maltby Mick (see "Mick's MMP Bits")... Mick's use of chamical blackening of the individual leaves is probably the best way forward.Also note in the instructions there is a keeper plate to be soldered across the bottom of the W-iron. I have deliberately left this off for the moment. Part of a cunning plan which I shall have to see if it works, because the observant may have noticed that the rod for the spring hangers has not been soldered in. At the moment if I remove the pins then I can drop the springs and wheelset out of the wagon - the cunning plan is that this might make it easier for painting later on - hence no keeper plate for the moment.
Having moved the threads for Mick I had spotted his comments about chemical blackening the leaves. I wan't sure about using Gun BLue on phospher bronze so have left it for the minute - although it's something I will try for the leaf springs. My cunning plan revolves not only around the leaf springs but the wheels and bearings as well. If I can drop out the wheel set at the painting stage then I can paint the wheels and axle boxes separately with a spot of masking tape or maskol over the bearing surfaces as required. Then I think a little subtle dry brushing may suffice for the leaf springs.The question of how to avoid paint / weathering getting between spring leaves and gumming up the action is one that I have asked of Maltby Mick (see "Mick's MMP Bits")... Mick's use of chamical blackening of the individual leaves is probably the best way forward.
As mentioned previously - next up are the springs.
As indicated in Christian's photo build the instructions say fit the brass rod in the spring hangers and then when fitting the spring to the W iron carefully slide the top leaf first one way and then the other to slide it under the rod in the spring hanger. Well it was tricky enough to fit the top leaf in the first place never mind sliding it one way or the other. So I took a "leaf" out of Christian's build and fitted the axleboxes to the W-irons before fitting the rod into the spring hanger.
As ever you are quite correct, however in my defence they all (Simon, Dave and Christian) operate under the same Building O gauge banner so it's an easy mistake to make.Adrian -
I think you'll find it is Simon's Build - I thought I'd better mention this before he wakes up in the morning!
I will be I interested to see how you tackle this wagon as I plan to build some MMP all brass kits soon and it looks like they don't lend themselves to making the w-irons removable,
ATB Mick
"New wagons" means... which of your current range are included in the warning?... particularly as the new wagons have the 'yoke' on the inside of the brake shoe that goes back around the inside of the wheel ...
We wish to be able to exchange wheelsets were possible as our home layout is 33mm gauge whilst the local clubs use 32mm.
and back is a non-starter. I mean, where do you site the brakes, how far away from the wheels to clear the different flanges? And isn't that going against everything S7 stands for?It wasn't exactly easy to get the wheels off the real things either........
I would have thought that trying to switch from 33 to 32 (or 31.5) and back is a non-starter. I mean, where do you site the brakes, how far away from the wheels to clear the different flanges? And isn't that going against everything S7 stands for?
Confused of rural bumpkinland
.I don't really want to remove the wheels once it's finished. It's just that when building the kit it gets frequent washes to clean off the flux and debris and I'd like to avoid getting the steel wheels any where near the water for as long as possible.I cannot see why you would really want to remove the wheels.
[snip]
We use essential cookies to make this site work, and optional cookies to enhance your experience.
