4mm Llanfair
paulc
There was to have been a gentle 'S' from the station to the hole in the wall, but I'm now going for a dead straight section. The track is sprayed, but it can't be glued until the weather cools down. Thought was given to having a tunnel instead of a bridge, but I was surprised to find no grown-up tunnel portals in the Web...
Outside the shed with the lid removed. The holes were cut for 0 gauge so are a tad tall....
Hi Larry , I'm not questioning just wondering why you decided to have a straight run in to the station instead of the gentle 'S' ??
LarryG
The station and yard was full of curves, so I opted for for a straight run from the bridge to the station. Also saved me messing around with super elevation.
LarryG
It's taken a good while getting there because of distractions, hot weather and indecision, but the last piece of Peco Code 75 track was glued and ballasted to the scenic board this morning. I must say it has been a pleasure to lay because the old Streamline retains its form and is a doddle to lay perfectly straight.
Its needs wiring up followed by weathering...
paulc
Hi Larry , that's looking good .
I would call that photo ' shades of layouts past '.
LarryG
After much deliberation, I rebuilt the old cattle pen using left over posts and wire to block off the non-railway side and make it end-loading....
Sprayed with Howes Sleeper Grime, it's new home is in the good yard with some of the "land" rebuilt to fit around it. As an aside, this photo shows the severe distortion the goods shed loading bay suffered from damp + heat....
This picture gives a better idea of how things are at the mo. The plywood is still waiting for a covering of 1/8" cork. I've also removed the widened part of the baseboard. The ballast has been spray-weathered....
LarryG
Rails were painted with PPC rusty rails colour and so that bit's finished. I'll remain satisfied with Peco Streamline so long as the Peco uncoupling ramps do their job.
The Peco Streamline Code 75 points look reasonably bullhead because of the prominent mouldings holding the rail, so I feel it is a shame Peco went in for non-matching flexible track.
In the meantime, I have now to completely re-felt the shed roof.
LarryG
The fine grey ballast (Woodland Scenics) was filed down to dust this morning. It all looked a bit bland for the moment....
Then I rigged up the compressor and spraygun. A Rusty rails colour was sprayed close to the tracks. Aerosol matt black and white primer were decanted into an old aerosol lid to make a dirty black and very much diluted with cellulose thinners. This was then sprayed around the coal bunker and where road vehicles would run...
It's all a bit fresh but the UV will tone things down eventually. Grass has yet to be added, but I tend to do that in one go over the length of the 14' layout so that it kind of matches....
sjp23480
Hi Larry,
Looks great, but a quick question.
When you say "file down the fine grey ballast to dust" - can you explain why and how you do this?
Sorry if this is a stupid question, but I was curious.
Thanks
Steve
