7mm Gladiator Horwich Mogul
LarryG
It looks to me like thee grey/cream line on the footplate valance was thinner than usual. Applying the red line was awkward seeing as it was immediately under the running plate. Then I ruled on the grey line hoping to get some separation between it and the red line. Obviously, there is a bit more room to play about with in 7mm.
P A D
I'll be doing it in reverse as the grey and cream lines are in place. I'll make some attempts under the cab with the ruling pen to draw the red line above the cream, but if it looks like it's going to be a mess, I'll clean it off and abort the mission. Pragmatism rules!
P A D
My attempt at drawing the red line on the running plate valance wasn't all that successful. Unfortunately, the underside of the running plate wasn't smooth enough for work with the ruling pen and even tiny solder residues threw the pen off line. After cleaning off and retrying a number of times I gave up. After the last application I let the paint dry for about 15 mins before cleaning off with a dab of white spirit on a cotton bud. The idea was to remove the red from the grey/cream decal and leave a hint of red above where the valance meets the underside of the running plate. This was only marginally successful, but a suggestion of the red line can be seen. That was yesterday, so today I applied the power code to the cab sides and was then able to give the model a coat of semi dull lacquer with a touch of matt black to take the shine off. Here's what it looks like now.
20260629_144609.jpg20260629_144625.jpg20260629_144701.jpg20260629_144728.jpg20260629_144742.jpg20260629_144810.jpg20260629_144839.jpg20260629_144917.jpg
Next I have to add the glazing, make and paint the backhead and add the plates when I have them.
Cheers,
P A D
PS. I also need to reinstate the long drain pipes to the cylinders. I'd cut them back before realising that locos which still had the twin relief valves in BR days, still had the long drain pipes.
P A D
After removing the existing pipes I had to drill out the drain valves to accept new pipework. I considered using copper, but as the pipes are so long with no way to anchor at the front end, I thought it would be too vulnerable to knocks and would require constant straightening. I settled on 0.7mm NS wire and having studied images of the set up of the pipes and the drawings in the Wild Swann profile, I repositioned the new pipework to be more prototypical. Here's the left hand set dry fit before trimming and painting.
And the left hand side after fitting and painting. I sprayed the pipes with red oxide primer off the model then fitted and brush painted the copper. 20260629_194353.jpg
I thought the longer drain pipes would hinder the truck movement, but it's the steps which are the limiting factor to the side play on the curves.
Cheers,
