Again, many thanks for the info guys - really appreciated
I think I will definitely go with Finney units now - they look super.
My only concern is that the slots already in the frames could be too wide (12mm across)... Fingers crossed!
Another session at the workbench this weekend
Following the kind advice above I invested in some Finney early GWR hornguide units. They are very easy to put together and are of much better dimensions for the 517 chassis.
Following assembly, two were soldered to the frames for the compensated rear driving axle:
They aligned very well with the shape of the bottom of the frame (although you can see there is some excess at the top, which I aiming to keep unless the superstructure requires them to be taken flush to the top of the frame). Once the ride is sorted, I'll look at manufacturing some axle keeps.
The frames have now been soldered together (making sure that everything was square using an axle alignment jig (configured using the coupling rods laminated earlier) and engineer's square (the spacers are the S7 spacers which come with the kit)):
Unfortunately, the blue now looks a bit ugly!
I've also managed to make a start on the compensation system, which, although very cleverly designed to fork around the motor and gearbox, I found a little bit fiddly to solder and fold up to clear the motor and gearbox assembly and the hornblocks (another reason I am glad to be modelling in S7 - the clearances are just that much more generous for my clumsy work :
The clearances are still quite tight:
That's all for now.
Next steps will be to set the ride height for the wheels and compensation beam and fix the mechanism in followed by starting to detail the chassis.
Time for a beer!
Were the wheels reprofiled by Christopher Makepeace ?
JB.
Very nice and clean work. How much clearance is required for the bottom outer slidebar? What about thinning the top of the bush or the bottom of the slidebar?
What is the purpose of the rod between the two valve rods?
I must admit, I can't really think what it might be for other than some kind of steam chest pressure gauge pipe perhaps..?
JB.
Suppose the hole/rod is for a modelling need rather than a prototypical bit of kit? Given that the kit design includes compensation, might this be the pivot for the front axle? I am not aware of Swindon fitting steam chest gauges to any engines contemporary with the 517 class.
Looking Nice Adam, but one of those pictures raises a point that one of us S7ers should have spotted a lot sooner...!
What width frame spacers are you using? Do you know what the width of the frames was on the prototype? I'm pretty sure that the wheels on the prototype would have been taking gouges out of the frames....
JB.
See if you can find out what the width would be, but I'm guessing you may need to widen those frames by about 2mm at least... I don't know too much about these engines, but all of the 0-4-4/0-6-2/2-4-2 engines that I have built so far have frames at full width behind the drivers to fit in the valve gear, with cranked narrower frames behind any guiding wheels to allow for the sideways movement for a pony or radial truck..
It would be interesting actually to know wether it was a radial truck (rather than a pony truck) on the 517 class, as in drawing some up in 3D for use on my N7 and F5..
If you do find out that the frames need to be wider, and you choose to go ahead and amend them, yes it's a small bugger, but the visual impact of having the frames nearer the spacers is massively better...
JB.
I just wish I had noticed it in the earlier pictures..! Sorry mate...
JB.
