oldravendale
Reviewing this thread I find that I said, in August last year, "I'm guessing that this build will take at least a year." Well, the tender's getting there.
Today was fixing the coal rails and beading day. Here's the results so far.
Inevitably more issues with which to deal.
Firstly the design of the coal rails is such that the back forms a right angle with the sides. We know that the back of the tender was the wrong profile, and so are the coal rails. As shown previously the infills for the sides were also too narrow and too short. These have been replaced and the ends of the etch for the back had the ends radiused, as were the ends of the infill pieces. This gave nice radiused corners to the coal rails with the join between the sides and backs within the radius.
Within the kit there are no fixings for these coal rails. Having looked at the drawings there appear to be some stanchions so I have recreated these and these are what fits the infilled coal rails to the tender top. These were made out of 1mm "T" section and fitted to the coal rails using 179 degree solder.
The beading was made as described previously using straightened 1mm copper wire. I fitted the beading to the coal rails after the stanchions using 100 degree solder.
Once the coal rails were a complete sub unit I soldered this to the tender body using the stanchions and 179 degree solder paste and a resistance soldering unit.
Then came fitting the beading around the top of the tender flares. This was done again using 100 degree solder, with a resistance soldering unit. The major issue here was to avoid melting the tender corner flares, and I managed this by the tried and tested means of holding a pad of wet bog roll over the corner. Fortunately it worked.
Here again is a load more work than appears necessary because of the short comings of the kit. I used the coal rails and the back etch (even this had to be filed down for height). The infill sections had to be replaced as those supplied were inadequate. Then I had to make the stanchions and the beading. Of the four pieces in the kit two were replaced, so what should have been a four piece assembly turned out to be 19 parts.
Oh happy days! (And I still think we're mad).
Next is, I think, to fit the white metal parts, tender interior detail and footsteps. I'll not fit the brake parts until I've decided what to do about the brake cylinders etc. The more time I spend on this the less I'm inclined to go to great lengths in fitting parts which will, at the end of the day, be unseen.
I've already discovered that there are no buffers in the kit. As there is no list of parts it's difficult to establish whether these should be present or not - also some people who have this kit say that there's more than one type of dome included, but I only have a single one. However there are two chimneys, and some say there is only one in their kit.
Once again, in pretty well every respect this kit is lacking.
Brian
![IMG_5229.JPG IMG_5229.JPG](https://www.westernthunder.co.uk/data/attachments/50/50217-68c6e2bdb89d168911a860cd7ee5ae15.jpg)
![IMG_5230.JPG IMG_5230.JPG](https://www.westernthunder.co.uk/data/attachments/50/50218-0ab5bf995cae17e08a94024ec49c8620.jpg)
![IMG_5231.JPG IMG_5231.JPG](https://www.westernthunder.co.uk/data/attachments/50/50219-4df0615e4c8fe202f21f723182dd9692.jpg)
Brian
