I must admit to having found the extreme heat hereabouts rather enervating so haven’t ventured into the modelling room for a few days. However, some welcome relief with rain today has dropped the temperature and I have returned to the restaurant car.
Firstly to finish the underframe I bent up and added the second steam heat/vacuum pipe (I’m assuming one side was one and the other, the other…). Looking at where I had soldered the footboards to the bogie, I realised one end of one spring had turned into a blob in the process. I therefore had to carefully saw off the blob with a piercing saw and add a prosthetic spring end fashioned out of plasticard strip. This was then superglued onto the rest of the spring.
Underframe and both bogies were then cleaned and sprayed with grey primer.
I then turned my attention to the body. The ends are made with two layers; the back one being full thickness with half etched lines to bend out the footsteps and the front half etched with slots to receive the said steps. I have managed to form the tumblehomes on all four parts, bend the steps and get the two assemblies matching both the end of the sides and each other. Tomorrow morning’s job is to clean the inner surfaces, add in a quantity of solder paste, ‘borrow’ a couple of wooden clothes pegs and wave my soldering flame gun over them…
Some photos attached.
Nigel
