Afternoon all,
Well, I guess it's time for me to break cover. Having seen Mickoo's Bulleid Light Pacific, 7mmMick's M7 and Dikitriki's Princess Coronation it was time for me to see what I made of one of Martin Finney's kits.
I built an M7 and T9 many moons ago in P4, so time for something different. I'm going to be working through an Adams 'Radial' tank, this one including a detail variant; a Drummond boiler.
There were a couple of these boilers built for the Radials in 1907 to provide spares for the class. They must have worked well as they both made it through to Nationalisation and both were carried at various times by all three of the survivors on the Lyme Regis branch, as well as a fourth loco. This variant has not been available from Martin Finney before and so I started work on a fret and backhead pattern to cut down the amount of work required for a builder to attempt the conversion.
The distinguishing features of these boilers are the dome-mounted safety valves, which is a typical feature of all Drummond boilers. These can be seen clearly in this picture of my intended loco, 30582.
I'll drop in pictures of the other parts as I go, but here's some views of the frets. First up the chassis, 28thou nickel-silver, exactly as Martin designed it. This is most of the chassis and also includes boiler formers:
All the following frets are in 16thou brass (to allow for polished brass bits on the finished model where required), most parts are bodywork related, but there are also a number of chassis details.
And below are the new fret(s). At the top of the image, the small fret will allow us to offer the 'Drummond boiler for Adams locos' backhead as a separate item which I hope will be useful if you're doing such a loco. To the best of my knowledge it's not available elsewhere in the trade.
Below that the main fret contains (from right hand end, clockwise):
Boiler wrapper to save patching around the firebox and fitting of new boiler band cleats.
The circles are parts to allow a loco missing it's cover plate behind the smokebox to be modelled - as 30582 was when withdrawn. Surrounding them are various small Drummond cab fittings.
Upper left is the boiler joining piece including various cleat positions depending upon which loco you're modelling.
Next to it are the semi-circular cab-front beading, a set of Drummond handwheels and two (unfortunately miss-etched - this will be solved!) firehole doors.
There's also a new cab front, with the positions of the different cab front fittings. Again, this saves having to patch and drill the original part:
There'll be more shortly, at the moment the important thing is to check that the new boiler forms correctly, that the backhead etches and castings fit each other and that the cab front is dimensionally the same as those provided to Martin's artwork, plus of course I need to check that there aren't any other errors I need to catch! Once I'm certain it all works as it should this variant will be made available - hopefully very soon.
I'll also be taking a good few pictures as I go. Some will appear here and others are to help with providing photos for new instructions.
