Ok, another update, and this time your narrator and blacksmith made a right good cock up!!. I had reached the stage where the body stiffener/chassis mount needed to be made, this basically is formed from three cross members and two side strips and is quite precise in its fitting, Fred gives the measurements in thou's. Basically the cross members need to be 2864 thou across and after my first attempt i had the side strips on and i was in a thou either side of the given measurement and it fitted in the body a treat. Then i came to try the chassis for fit and found it would no go all the way in, i looked and it dawned on me, i had soldered the side strips on upside down
. Oh bugger is the censured version as it all had to be unsoldered for another attempt, and yes i do know i really should read the instructions first.
A couple of wasted ours later saw me end up with this,
This time with the side pieces the right way up !! incidentally the loose bits on the end help with lining up inside the body and get snapped off after the assembly has been glued in place.
Here is a picture of it on the chassis, and a trial fit in the body,
There are three screw holes with captive nuts to hold the chassis on but as it's a snug fit i hope not to use them, i have to find that extra strength Araldite now, hopefully my next bit of progress will see me reading the instructions and no more cock ups
cheers Rob,
