Heljan BR class 02, conversion to S7
Buffers and front handrails New
  • RichardG
    This seems like a good time to start doing some actual modelling. Let me see how this goes before I spend money on better wheels.
    The handrails beside the front steps could be better. These are of plastic, fixed to the buffer beam but not the bottom step. I imagine, Heljan have done this to let the buffer beam be a removable subassembly. The handrails are too thick and to me they just look wrong.
    This is an original handrail and an experimental replacement.
    The new handrails are of nickel silver wire (diameter to match the brass wire handrails on the model) with top brackets drilled and cut from 1 mm square styrene. When I stick these on, the buffer beams will be fixed onto the model. I want to decide on the buffers before I do this.
    The Heljan buffer heads are completely flat, while the photos I have found show buffers of the usual curved shape. Please, does anyone know of flat buffer heads like the Heljan ones? Perhaps on different classes of locos working in industry.
    To make things easier, I want my model to be an unidentified ex-BR loco, now working in industry or possibly preserved. I’ll imagine it is one of the locos which was scrapped upon withdrawal from BR.
