geoff_nicholls
looks excellent. What is the height of the bottom edge of the facia which conceals the lights? Being only 5' 4" myself, I can't judge how high to make it on my layout.
Hi, guessed correctly it won't be 3 link couplings, it will be automatic uncoupling. There's a few that use Alex Jackson couplings but the majority coupler is the DG Coupling. I've just bought a couple of small solenoids for working them and then I saw a suggestion of using a rare earth magnet and physically moving it into position which is something I'm considering.I was going to ask how you avoided getting blinded as you uncouple wagons, but I guess you're not using 3 link couplings?
. Technically they are Trap Points. Trap points usually face a trains direction of travel and deliberately derail rolling stock in the event of a forward moving unauthorised movement. Catch points (usually spring operated) are those designed to derail rolling stock on a uni-directional line when it rolls back in an uncontrolled manner in the wrong direction
Not so. Both are trap points and are there to protect the main platform line (even though its technically a shunt neck at that point) from any non-passenger overrun movements from the runround loop or sidings. This was probably done with the thought in mind that the line was going to be extended at a later date as mentioned in posts further up in this thread.Interesting, I didn't know that, so, looking at Adrians set up there is technically one trap and one catch point within the normal point?Mick D
Thanks for that - I do think it was necessary as it is quite a prominent feature of the track work. Fortunately it wasn't that difficult to incorporate even in 2mmFS - although I have had to go to the opticians for a stronger pair of reading glasses!!Anyway, I am extremly pleased to see that Adrian has taken the time to incorporate this into his layout (its not easy to replicate that arrangement in 0 Gauge let alone 2mm FS)
... so I have decided to follow Jerry's advice and just use a moving sleeper for all of the switches (turnouts and traps). The 2mmFS members seem to have invent more solutions for tiebars and point actuators then all other scales combined! but with the interlaced sleepers the only solution seems to be the moving sleeper, it also helps that it's the easiest!!
Sorry - my apologies. Jerry is one Jerry Clifford, an enthusiastic and vocal promoter for 2mmFS, builder of Highbury Colliery, Tucking Mill and Bath Green Park (which we need to see more of!) and occasional guest editor of MRJ.Sorry, but being relatively new to this forum who is Jerry and which layouts are you referring to?
