Ian Rathbone
The first stage of cleaning, as part of construction, is to physically scrape away excess solder and any green or white deposits from excess flux using whatever suits the situation - scalpel, fg brush, dental scraper etc. When I consider it ready for painting the next stage is to use a detergent to thoroughly clean it. I use a floor cleaner as it has no lanolin in it. A detergent is a ‘wetting agent’ in that it reduces the surface tension of the water, allowing it to get underneath dirt and wash it off. It is also alkaline so may help neutralise an acid flux. I use an ordinary 1” paint brush to apply a strong solution. The brush is quite stiff but its bristles are long enough to avoid damage to lamp brackets etc. A good rinse follows.
The next stage is dry the model and further check for foreign bodies. I then brush on a neat limescale remover which will remove the tarnish and clean the brass. Now the brass does not need to be shiny, I do this stage so that any further foreign bodies show up better. An alternative for this stage is to use ‘Barkeepers Friend’ which comes as an abrasive powder that cleans the brass but leaves a dull finish (but also needs careful washing off). Rinse again.
Finally a check for hard water deposits, wipe over with cellulose thinners (or white spirit) to remove any finger grease, and that’s it. Gloved hands from now on.
Ian R
PS. There is a good book that I know of.
Ian R
