To make ride height adjustment a little easier, a couple of notches indicate midpoint, helping set the ride height...
Now that is a nice touch and one which I hope other kit designers will plagarise.
Thank you for that idea.
anyway thinking time is never bad and I thought to hedge my bets I would etch two lots of horn guides with different wire spacing. There will also be a second set of 'sidepods' and ends to fit easybuild MK1 sides should anybody wish to attempt fitting them.
so I thought I would try and get to first base with the Wessie cabs, there is quite a bit still to do, like getting the drivers hands on the controls
and it all needs blending, but its going in the right direction.
I know Dan is horrified by this but I use a milled brass strip soldered across all the brake gear. Two reasons for this - the rod is gives a nice straight line, and secondly it is much stronger. Once the bolster is on and its painted nobody has ever noticed
I also very much like usable working models with the inevitable compromises that they need to work well IMO
