7mm MOK 8F - 8425
Rob Pulham
I have had the most frustrating time since my last post on the 8F. It started when I made my first attempt at improving the return crank offerings in the kit. Like pretty much all etched LMS loco kits, the four retaining bolts (which are in reality recessed into the face of the return crank) are represented as four half etched bumps. Or rather the bumps are full thickness, but the surround is half etched. They usually have a second backing layer to make the return crank up to the full thickness.
The original plan was to drill through the bumps and insert some rod to represent the bolt heads. I confess that I failed miserably to get four holes centred on the bumps. Luckily, I had an additional pair of etched fronts in the spares box which I tried first.
Then I thought perhaps I would make a better job if I drilled out the backing layer and placed that over the ‘front’ layer to leave the etched bumps inset. This I have to say worked perfectly. Sadly, it all fell apart when I soldered the two together. Solder leeched into the holes and filled them completely covering the bumps.
I tried plan B, which was drilling the holes out again and inserting stubs of rod into them. This too failed miserably in so much as the holes ended up offset and the results looked a bit like Marti Feldman.
It was at this point last Monday when I inadvertently rubbed something (I am not sure what but it may have been flux) into my eyelid. It immediately started to itch like mad. By Tuesday morning my eyelid was so swollen that I could barely open it. Tuesday and Wednesday were spent sat listening to audiobooks, with frozen teabags on my eyelid trying to get the swelling to go down. By Thursday I could open my eye a little and I was feeling a bit stir crazy, so decided to go into the workshop and do something.
I started by scanning and importing the outside motion GA from the Wild Swan book into Fusion 360. I scaled it to 7mm scale and sketched the return crank creating a 3D model from it and then from that created a working drawing.
Taking measurements from the drawing for the holes, I transferred them onto some strips of nickel silver which I had cut at 6mm wide. I had prepared 3 strips one for the front layer with 1.6mm holes, one for the back with 0.9mm holes and a third which I drilled with small holes at one end and larger holes at the other. Having something firm to grip in the vice of the Proxxon Mini Pillar drill and using the coordinate tables I was easily and repeatably able to drill the multiple sets of four holes. I also drilled the hole in the other end to tap 12ba for the fixing. More on this later!
At this point I decided to solder them together, then make and fit the simulated fixing bolts. With the view that if I couldn’t get that right at this stage of the proceedings, then there was no point in wasting time filing them to shape.
On my first attempt, I had filed some hex ends on some nickel rod and soldered that into the holes, but this time I decided to see if I could improve upon that. I cut a short length of 1.4mm nickel rod, fitted it in the 3-jaw chuck on the lathe. I would normally have used a collet but the chuck was already mounted so I thought I would see if it tightened close enough to grip such a thin rod. It did so with some movement to spare.
With a very sharp HSS cutting tool, a fast RPM and a very light feed rate, I was able to cut the end of the rod down from 1.4 to 0.9 in one pass. The secret is don’t have too much sticking out of the chuck. I would guess that I had no more than about 6mm protruding. I did this on each end of the rod and then transferred it across to my hex headed pin vice. Using the hex head as an index I filed a short length of the full width rod into a hex to represent the bolt head. Then using my trick of gripping the tail end in a second pin vice to prevent it flying off into space when it cut through, I sawed it off with a piercing saw.
I confess that I found making them quite therapeutic and I got a little sidetracked. I was also amazed at how much of the rod I was able to actually use.
Remarkably quickly I had the eight that I needed and a few for the spares box.
Rob Pulham
Having soldered them into the holes before cutting the return cranks out I idly wondered just how small hex bolts I could make without wasting lots of material by cutting them from thicker stock. So, I cut a short length of 0.9mm nickel rod and was again surprised that my 3-jaw gripped it. I increased the speed again to approx. 2000 rpm (my lathe supposedly goes to 2500 rpm but I didn’t have it on full speed).
On the first try, I had a little too much stick out and almost immediately the end of the rod bent away from the cutting tool. Undeterred I snipped the bent end off and tried again with roughly 5mm stick out. Using a very light touch to allow the speed of rotation and the sharpness of the tool to do most of the work I was able to reduce the stock from 0.9mm to 0.5mm again I did both ends and transferred it to the pin vice for finishing.
I made a few more just to confirm that the first two weren’t just a fluke.
They do need a touch more finishing with a file to reduce the depth of the head to something more bolt like but that’s the easy bit. The more difficult bit will be holding them and fitting them into holes without them pinging off into the ether…
Rob Pulham
After far too many attempts I am almost there with the return cranks. Both my hand filing and my measuring proved inept, when on one of the attempts I managed to forget to take account of the radius of the big end and the whole thing came out a good 3mm too short. To be fair even if it had been the right length, it looked awful too.
For the next and hopefully last attempt I drilled all the holes and made sure that they would centre over each other on the two layers then I soldered one end together and before adding the bolts I carefully marked up the shape of the crank where it transitioned from the big end to the smaller end.
Next, I gripped the crank at an angle in the mill vice (using a parallel to ensure that the edge line was level and then milled down to my marked line on either side.
After some cleaning up and going around the raw edges with more solder to ensure that they remain as pairs I fitted the retaining bolts. I did manage to rescue all eight from a previous iteration then I dropped three of them as I was fitting them to the new cranks.
After coffee and while typing this post, I decided to have another look to see if I could see any of them and was pleasantly surprised to find two of them. They are so small that I didn’t expect to see them again.
Rob Pulham
It is with much relief that I can report that I have finally made the return cranks to my satisfaction. I turned a couple of thin nickel washers to give me a circle to file to and to space the eccentric rods off the face of the return cranks to clear the bolt heads.
Hopefully I will get the rest of the motion assembled and working tomorrow.
Rob Pulham
After taking a few days off to do a video for the upcoming Gauge IO Guild Virtual show I returned to fitting the motion on the 8F. True to form it continues to entertain and frustrate in equal measures.
I started by fixing the links between the Drop Link, Union Link and Combination lever together with the pins and retaining washers that I made previously for the task.
It was once I had these assembled that I realised that once fitted in place the crosshead travel in the slide-bars was being limited by something and as it was it wouldn’t allow a full revolution of the wheel.
This was the limit of the forward travel. Initially I tried a bit of filing of the combination lever to see if that would allow it to move further forward.
This didn’t make any noticeable difference and I came to the conclusion that it was the fit of the combination lever in the “valve block” (? – I don’t actually know what this part is called)
This is what I came with the kit and I had drilled out the hole which was cast as a dimple on the centre line. I concluded that the hole for the retaining screw was too far forward causing the front of the combination lever to hit the lower front edge of the valve block causing the travel to stop at that point this conclusion was born out when I took it apart because one of the valve spindles had bent under the pressure.
I had also enlarged the side openings in the valve guide castings to allow better fore and after movement of the retaining screw.
Having reached that conclusion I decided rather than try to drill out the existing valve blocks and potentially wreck them that I would make some replacements that were a little longer so that I could set the hole further back.
As is my usual practice these days, I measured the castings that I have I modelled it in 3D.
From there I created a working drawing
At this point I decided to make one to test the theory. If successful I would then document the second one.
Rob Pulham
Rob Pulham
The first one was a success in terms of increasing the range of movement I made it from 5mm Nickel bar and in the end, I made four.
Ultimately leaving me with this
The two valve blocks together
This is the difference that they make in the amount of travel.
One problem solved so onto the next…
Rob Pulham
When I mentioned them a couple of posts ago, I had also forgotten to post the retaining pins that I had made for the other joints.
I was a little concerned that I had the heads too thick but having looked at the GA and a number of photos, I have them about right.
These, were another little job that was quite satisfying and very therapeutic.
Stepping back slightly Ian Allen (@Lancastrian ) posted on the Guild forum that he’d had to add a small piece of brass angle to the rear of the valve guide casting to prevent the valve block from lifting. After making a note of it in my mind to watch out for, I was thinking about the potential problem while shaving this morning and I realised that I had probably solved the problem without realising there was a problem to be solved.
My retaining screw for the combination lever in the valve block is a 14ba steel screw which screws in from the back. The head of the screw protrudes into and slides, in the slot in the rear of the casting which I had enlarged previously.
I had done a similar arrangement on the Princess.
dibateg
Nice work on those valve rods Rob! I've found in the past I've had to drill the hole for the combination lever further back because of clearance problems...
Rob Pulham
Thanks Tony,
It's the first time that I have encountered it but it's not something that I will forget in a hurry.
On a related note, those who take notice of such things may have noted that I cut out the rear of the valve block instead of inserting the combination lever through the enclosed slot. This is because I had previously added the angled oil pot to the bottom of the combination lever meaning that the narrow end would no longer go through said enclosed slot.
As ever you add a little detail to improve things and generate several other little jobs as a consequence...
Dave Holt
Another possible approach, which I've used in 4 mm (and not having machine tools) is to file away the bottom corner at the front of the valve cross head to an angle to allow the combination lever more swing to the front. Obvviously, this requires quite a thin file with an edge cut.
That said, I usually fold up the cross head from strip, or have an etched version made, as cast items are rare in 4 mm.
Dave.
Rob Pulham
A friend has asked me to reiterate to anyone joining this thread more recently, that the MOK 8F kit that I am building was bought in 2010 and has been upgraded by MOK at least twice since then. Just in case anyone reading the thread is put off buying an MOK kit by reading my journey.
Additionally, when I started building it back in 2012, I didn’t have much experience (or confidence) in loco building. Hence mistakes were made by me and no fault of the kit through inexperience\lack of confidence. Which I now need to revisit having gained experience and confidence to rectify those mistakes in the meantime.
The latest of them being the realisation that the two rear compensation beams don’t move fully in one direction which leaves the second from the rear axle sitting lower than the others without any upward movement that should be allowed by the compensation beam.
Examination of the chassis has revealed that the issue is caused by my siting of the spring hangers for the second axle so I need to take them off and make adjustments to allow the full range of movement
It also doesn’t help that I had gone so far in building the kit as an LNER 06 but when I bought the whistle of Swindon Built 8F 8425 and decided to base my model on that example instead it required a few changes. Which are again, nothing to do with the quality of the kit as supplied.
Rob Pulham
Well, that proved interesting. I removed the two offending driving wheel springs and I confess that I was surprised when that didn’t fix anything. The restricted movement still remained, so further investigation was required.
Looking a bit closer revealed that the problem was being caused by the compensation beam hitting part of the ashpan/gearbox housing arrangement.
Apologies for the colour of the photo, I have heavily contrasted the image to make seeing the issue easier.
Once I worked out the issue my first thought was how the devil do I get in there to cut out some material to allow more movement. I couldn’t see how I might get a piercing saw in and although I do have a shallow bladed razor saw, that was too deep to go in. The last resort saw wise, was to try a hacksaw blade. That too wouldn’t fit. Then I realised that if I unscrewed the motor retaining ring it might be possible to get a milling cutter in.
I gripped the chassis in the mill vice and with a 2mm two flute slot drill I carefully milled out a slot either side taking care just to go through the two layers of etch without hitting the compensation beam.
Now I just need to refit the spring castings
Rob Pulham
Well, I would be lying if I said that getting the chassis running with all the motion fitted was anything but a trial. Much of it my own doing. I am not sure how but I had scaled the drawing wrong so my many attempts were all destined to failure I just didn’t know it yet. It was mention of the scale size of one of the rods that Ian Allen @Lancastrian) posted on the Guild forum that made me double check and find the error. A trial assembly of the final version of the return cranks confirmed that they were indeed almost a millimetre too long between centres.
I confess, that this almost did me in and I nearly consigned the 8F to its box for another decade. Saner heads prevailed and I recalled the drawing, redrew the return crank in Fusion 360 and created an updated working drawing. From there I made a ninth set of return cranks and again I made an error in so much as I pre-drilled the cranks and the small bosses that I added to clear the ends of the studs protruding above the face of the crank. When I then soldered them together, I hadn’t noticed that the holes were slightly out of line until I tapped them the tapped them and the tap went in at angle. So, I started again and this time I made four return cranks with the view that I could pick the best two.
This was taken part way through making them. – I did trim down the boss on the deeper pair after testing.
Having taken great care in the shape of them I also only drilled a pilot hole in the bosses. Then I clamped the cranks to my Metalsmith drilling plate in the mill vice and drilled right through to ensure that all the holes were aligned.
Next, I used a small engineers clamp to clamp the cranks to my tapping jig to ensure that the tap was aligned to the hole and then they were tapped 12 BA
I also used my homemade tap spinner to reduce the risk of breaking the tap.
Finally, I had two pairs of cranks fitted with miniature studs
A test fit had me heaving a sigh of relief as they fit and the motion turned over under power but there were a few clicks where the bits were catching. I knew that clearance was always going to be tight so I patiently worked my way through the various parts easing them.
They included but were not limited to, filing two etched bolt heads off of the insides of the expansion links; filing the bottom front corner of the new valve blocks to allow a minute amount of extra forward travel; turning the head of the 14ba steel screws that retain the combination lever to the valve block down to the thread thickness while retaining the slot, to allow them to be easily removed. Again, to allow a minute amount of further forward travel; easing the faces of the connecting rods to allow the expansion link to pass without catching. – Incidentally I measured the thickness kit provided connecting rods at 1.7mm and the Premier ones at 1.5mm so had I used the kit rods that problem would have been exacerbated.
I also replaced a couple of 14ba brass screws (which retain the expansion links) with some homemade nickel silver replacements with the view that they would be slightly more hardwearing than the brass ones. In fairness given how little mileage my locos actually do. this may have been overkill on my part.
After all that I had a smooth-running chassis. The tinging noise that you can hear is because I haven’t permanently fitted the retaining pins that hold the radius rod and the combination lever together yet so there is a bit of slop in them.
Rob Pulham
Now that I have the chassis running, I decided to move the body along a bit before returning to the chassis to fit brakes etc.
The next job is to drill/mill out the holes in the steam pipe casings that are present on some, but not all it seems 8F’s. Mine has them of course. Upon investigation of the drawing and peering at many photos, it seems that the hole isn’t a full circle. It’s just over 2/3rds of a circle and it goes right through. Basically, what I need is a 2mm hole set 1.7mm into the bottom edge of the castings.
The next problem to solve is, the age old how do I hold the castings in order to mill/drill them. Because they are such an odd shape, I dug out my angle blocks and after much testing and head scratching, I came to the conclusion that I couldn’t see a way to hold them in the vice at the right orientation to do the job (in hindsight a 2mm ball nose endmill might have done the job).
It was at this point that I remembered that for Christmas 2024 my son had bought me a couple of Hemingway ‘kits’ for workshop tools. One of those ‘kits’ was for a Finger Plate. Which is a 2in x 2in block for clamping and drilling small objects. So, I decided to build it to allow me to machine the castings and no doubt many more in the future.
Eight days of machining later, it took less than 20 minutes to do the job…
Rob Pulham
After my diversion in to finishing the bolster wagons and mostly building the 3D cranes this week I returned to what I view as proper modelling.
having done quite a bit of work on the steam pipes the next job was fitting them. The main issue being how to hold them in the right place or rather correct height above the footplate for soldering. I came up with the idea of making a spacer button and after much careful measuring I turned up a steel button that sits on my wooden cradle and when placed under where the steam pipes sit the step down fits inside and protrudes just to the height of the footplate leaving the casting sat inside the riveted overlay around the base of the steam pipe. This overlay is half etched so tolerances were quite tight.
The good news is that it worked perfectly and I managed to get them soldered in without further drama
