Adam,
Sorry to be dense, having just cut through Podimore, was the intention to come off the W,S &W just south of Rimpton?
Hi Tim, not being dense at all, I have been vague about this myself.
Just south of Rimpton was plan A, and what I initially thought of. This would make Sherborne the more likely junction, I think, which is probably sub-optimal if you consider where Ilchester is. Mind you, a branch served from Yeovil Junction probably wouldn’t be very much better for the shops.
Plan B, which seems odd, until you think of the huge earthworks put up to get the Lyme Regis branch over the mainline at Axminster, would be a line diverging from the LSWR connection from Town to junction, skirting east of Pen Mill and the GWR and going over their line round about Trent and heading along the Yeo round Mudford, calling there, Podimore, and terminating in Northover.
Plan C, much more sensible, would involve running powers over the GWR before branching in much the same way as Plan B. Not impossible, given how railways around Yeovil worked, but also (given it took a World War to install a proper main running line connection between the two), perhaps the most unlikely: the GWR should have built the thing. That said, think of Portland’s railway history, which, if you don’t know it, defies belief, and all bets are off.
All this contradicts a lot of what I said in post 1…
I’ll sketch a map in a bit.
Incidentally, through work, I’ve come across a letter from the Parish Council in Mere, following the passing of the Light Railways Act enquiring about the possibility of a railway not to the LSWR, whose main line passes Gillingham more or less in line of sight from Mere, but to the GWR, whose routes locally are the wrong side of a very big hill…
