Overseer
JB, you really need the specific P&D Hobby Shop RC GP9 Repower Kit 2201K 4w/ Brass Trucks. The problem is, as mentioned recently in the US dabblings thread is that P&D seem to be out of stock. It would be a shame if they don't restock. Plus the matching P48 conversion kit from Right-O-Way. The P&D repower kit converted to P48 with the RoW kit run beautifully, smooth with low speed crawl. The kit you have linked to has a shaft through the tank which is not a great look, they might be able to add another tower transmission instead of the centre transmissions, and buy the truck frames separately. The brass bogie kit lowers the kingpin height to near footplate level and the drive shafts are below the cab window level. It would not be hard to drop the motor and drive shafts down lower if building your own mech. You need to be careful with NWSL wheels, I bought some 33" 'P48' wheels recently from them, They are nicely turned nickel silver but flat backed and the profile is not really to P48 profile, they have used something similar to the RP25 Code 110 profile but slightly wider - this means the flange is twice as wide as it should be. They still work but the relationship between back to back and effective gauge is different so could find tight spots through crossings. The flange profile is not very nice either, too square. I wouldn't waste too much time on the Roco sideframes, they are not very accurate and look quite toylike.After a bit of information to those in the know please.
Im looking at building a Red Caboose GP9 kit in the near future, and I believe that its possible to use the Atlas/Roco(?) F9 trucks, and although these run quite well I don't think they be quite as good as I'd like and also the gear and motor tower is quite substantial.
I have found a motorising kit here Drive Kit, Universal, Includes 8514 Ball Bearing Motor, Motor Mounts, Tower, end Transmission, 2 Center Transmissions and all Necessary Hardware to Power a 4 Wheel Drive Locomotive, P&D Hobby Shop: Drive Kit, Universal, Includes 8514 Ball Bearing Motor, Motor Mounts, Tower, end Transmission, 2 Center Transmissions and all Necessary Hardware to Power a 4 Wheel Drive Locomotive but does this work with the Atlas cosmetic sides, or need to source other sides? I only ask as I have 3 of the F9's in stock as I had a crazy idea about kit bashing the 3 to make an A-B-A unit.
Thanks for any info.
JB.
Protocraft p48 on left, recent NWSL on right.
