David Mylchreest
I have one of these in my stash which I acquired during a brief period of interest in NG . It has never occurred to me to do it in SG! I'm not sure it would be possible to compensate it though.
Hopefully my attempt at converting the kit to standard gauge won't put you off from doing the same.I have one of these in my stash which I acquired during a brief period of interest in NG . It has never occurred to me to do it in SG! I'm not sure it would be possible to compensate it though.
Don't think you're going to put me off at all! I'm most impressed by the tidy soldering, would that I could do as well.Hopefully my attempt at converting the kit to standard gauge won't put you off from doing the same.
I'm still debating compensation or springs for the suspension. A rigid chassis is out of the question due to the aforementioned dodgy track laying
I'd love to see another standard gauge version of this kit take shape, so maybe give it a go David.
One thing I've come to realise over the years is that when it comes to soldering you can never have enough heat! I've got a cheapo 80w soldering station which does most of what I need. Only occasionally do I get the old bruiser soldering iron out. Usually followed by lots of cleaning up of excess solder.Don't think you're going to put me off at all! I'm most impressed by the tidy soldering, would that I could do as well.
Have you chosen a gearbox yet? Must be coming up to that time and the model is so small.
) as to how to proceed will be greatly appreciated.Hi Rob.I bought some 2mm silver steel rod a while back via eBay. Being only 2mm, it was quite cheap.
That could work.Knitting needles size 14 are 2mm diameter. You could try a charity shop, roll them on the counter top to check for straightness.
Hi SimonMike,
what size are the holes in the coupling rods? Could you get some silver steel (or piano wire) of that diameter, and sleeve it with brass tube to get your 2mm? I guess it depends on whether a brass tube of the right ID and OD is easily available, but that way you don’t need the taper.
hth
The outside cranks are made of some sort of plastic, so soldering not really an option. But, I'm reasonably confident that they'll stay put on the axles. They'll be butting up to the wheel faces, so the addition of some glue should hopefully suffice.I'm wondering if the outside cranks need to be soldered onto the axles. I get anxious about soldering steel because of the huge amount of energy needed to do it. It might cause distortion and other details to fall off.
My experience is that extruded brass tube is as dimensionally accurate as silver steel and a lot easier to solder. The hole is easily filled with a bit of wire.
Sorry for the late and perhaps eccentric contribution .
I’m not sure why you’re suggesting steel is harder to solder than brass.I'm wondering if the outside cranks need to be soldered onto the axles. I get anxious about soldering steel because of the huge amount of energy needed to do it. It might cause distortion and other details to fall off.
There's no rush!120:1? Probably about right. Veerrry slow, certainly.
