1/32 Python P14's
Discussion in 'G1/32' started by Dave Bowden, 7 October 2019.
  1. Dave Bowden
    Dave Bowden Western Thunderer
    In Parallel with the 10mm Cattle Wagon I've now started on one of two Ken West Siphon C Kits.
    Two photos with what you get in the kits, photo three is the chassis assembled and glued.
    All the W Irons axle boxes & draw gear I shall aquire from Ken Martin, Wheels will be from Walsall Models (3' 6") Corner plates and hinges from Tenmille. Buffers from NMRS.
  2. Dave Bowden
    Update on the Siphon C's, first one now glued together but no further progress until after the Trade & AGM at the Fosse (parts required)
    The brass steam rally plaque is for added weight.
  3. Keith Phillips
    Keith Phillips Western Thunderer
    I shall enjoy watching the progress of the build. I have a number of adhesive wheel balancing weights if you would like some for this or future builds? I can bring them to the AGM.
  4. David Halfpenny
    David Halfpenny Western Thunderer
    DAVE,
    DON'T GO TO THE FOSSE ON SATURDAY !
    Go to Stoneleigh Park, Warwick Hall - and pop by the 1:32 Finescale stand.
    I'll be collecting a couple of Siphon G kits there, so I'm really appreciative of your Thread on the C's.
    Thanks, David 1/2d
  5. Stewart
    Stewart Western Thunderer
    Hi David
    I don't model in 1/32nd scale, but do like Siphon G's!
    Who produces the kit?
    Many thanks
    Mark
  6. David Halfpenny
    Ken West lasers very basic body-only kits from MDF.
    He's been doing Outside and Inside framed Siphon Gs in 10mm scale for £35 a pop.
    An article in the current G1MRA Journal covers the detailing of Ken's kits, including a Siphon G:
    but as to sourcing the gubbins, Ken just says 'Walsall', which doesn't work for everything you might need.​
    I've asked Ken to scale the Inside Frame one down to 1:32 (for a spoof ambulance train ~ hey if Bachmann can do it . . . ).
    I don't know whether he's rescaled the Outside Framed one.
    If you are interested in any scale other than G1 I'd urge caution, because while the laser lines are scalable, the MDF isn't !.
    Incidentally I got a good-enough Inside Frame diagram (not a full works drawing) from HMRS.
    Their website is no longer even on Life Support - best to email the hapless Sales Geezer who's very helpful.​
    David
    isambardme likes this.
  7. Dave Bowden
    I just received today Etches for my Siphon C's from Tenmille Products. These were for their Siphon G and are the corner brakets, Strapping Parts & Lamp Brackets code number G154E. On their G172E are the replacement hinges (these were w/m previously) and the following.
    Small V Hanger for Brake Lever, Large V Hanger for Brake Cylinder, End Steps, Brake Levers, Door Locks, Coupling Hook Reinforcing Plate, Brake Lever Ratchet & Centre Brake Cylinder Lever,
    This should save a lot of Scratch making. I will be at the G1MRA show on Saturday with these parts for anyone who wishes to view them. I will leave them on the Finescale table for viewing only!! I shall also have with me a selection of the plastic rivets that Jim Smith used on the models he wrote about in the latest NL & Journal.
  8. Dave Bowden
    Hi Keith
    I replied to you message via my email acc, did you get the reply? The answer was yes please if they wiil fit Walsall's 3'6" disc wheels.
    I'll PM you my Mob. phone number so we can meet up some time during the day.
  9. Keith Phillips
    Hi Dave, just to clarify the weights are for car / bike wheels. They will go in the van bodies as per my Slaters van build. I'll see you there, at Stoneleigh.
    Keith
  10. Dave Bowden
    Sorry Keith I think I got my wires crossed, I thought you were talking about the inserts that were fitted to disc wheels.
    Where as you were referring to car wheel balance weighs.
    Keith Phillips likes this.
  11. David Halfpenny
    Good tip, Dave because neither of those items is on the their online price list.
    I may give Tenmille a ring once I've got my kits home. D
  12. Dave Bowden
    It was nice to meet up with Keith Phillips & David Halfpenny at Stoneleigh Park last Saturday. And thank you Keith for the strips of weights.
    Here's a photo of the tenmille products etches that I shall be adding to Ken West's Siphon C. I noted that the corner plates are short of a rivet, I shall attempt to add one of the plastic ones I've just bought. I'll add a photo of the rivets later.
    These are 1mm 'Dome & Hex headed' 175 on each block and £2 each
    Front row 1.5mm same heads as the 1mm but only 100 per block & also £2 each
    Having seen Ken Martin's CCT's rolling on these bearing I thought I'll have some of that.
    Details on the pack, Price £13.13 inc P & P from HK. (snowspitzshop.com)
    I shall fit these to both my Siphon C's & my 3 Pythons and have a lot left over.
    isambardme and Keith Phillips like this.
  13. Dave Bowden
    Here's a photo of an outside Siphon G taken by me on the SVR, all the plates on the side can be clearly seen. 1257 Siphon G_2.JPG
    isambardme, LarryG, markjj and 2 others like this.
  14. Keith Phillips
    Pleasure to meet up with you too, Dave. Thanks for taking the time to explain a few bits and pieces and for showing me those Zings rivet and bolt heads. I enjoyed the show very much and feel inspired to get on and finish the Slaters van and then move on to the GWR brake van before attempting my first scratch build.
    Kind regards, Keith
  15. Dave Bowden
    Keith the rivets were from Zinge Industries Preston, just in case you are going to order any.
    jbsmith and Keith Phillips like this.
  16. Dave Bowden
    Hi all
    Update so far, it turns out the two Siphon C's I've assembled are 10mm ones not 1/32 scale. So I shall be getting new ones from Ken West in due course, I shall sell the two I've made, luckly I didn't start adding any metal work.
    Ken is going to redraw the C's as the diag o9 version which were 8' 6" wide. So in the meantime I shall make a start on the two P14 Pythons.
  17. Dave Bowden
    Here's the start on the P14's (two) both up to the same state.
    The weights I got from Keith Phillips at Stoneleight Park are attached to the floor. (car balance weights)
    These are definally 1/32 scale.
  18. Dave Bowden
    The two Siphon C's I put together will be going to a new owner on Wednesday hopefully. I've moved onto the 2 P14's as show above. On closer inspection with an original photo from Paul Bartlett they have some descrepancies, the 6 strapping plates on the side are not 4 holes only three. The two next to the doors should be right next to the bottom hinge, and 10 extra rivet holes.
    When I've finished one side I'll add a photo, meanwhile here's a photo of the hardware I bought at Stoneleigh Park show, with the exception on the buffers which I already sourced earlier. The brass items are all from Ken Martin.
    I've added the before and after with the Screwlink couplings, I've lightly treated the finished ones with a 25% mix of Birchwood Casey and water.
    The axle boxes will be opened out to take the the 5mm dia. roller bearings.
  19. Dave Bowden
    Here's a photo of side 1 model 1 of progress so far.
    6 strapping made of nickel silver and 10 holes drilled and filled with the 1.2mm hex headed plastic rivits. Squadron white putty is not easy to use as it dries out as soon as it touches the model, even thinning it down with nail varnish remover!! And I only lost one of the rivets somewhere on the carpet.
    I have to find some more 2mm strapping before I can continue.
  20. Dave Bowden
    Having looked at a photo of the prototype I've changed my opinion as to where the second strapping from the left is, in the photo above It's correct in relation to the the windows but wrong in the number of planks from the left. So I'm leaving it where it is.
    Here's a photo of the prototype No. W556.
    Now there something to compare with but still a long way to go i:e handles, door stops & ticket pouch.
    isambardme and David Halfpenny like this.
