Morning all..
I thought I would, from time to time, post some images of weathering.
I generally use just Humbrol weathering powders, sealed with Humbrol acrylic powders when done. The only paint that is used is the Humbrol Dark Earth aerosol sprayed on the underframes of some of tge wagons and the underframes of the coaching stock.
The locos are reliant on simply the powders and varnish.
I also yse the same colours for building, vehicles and track. I feel that this gives a uniform look to the layout.
First up are a selection of images of a Bachmann 3F. Pretty much stock aside from crew and coal.
I hope you like.
I hope you like.
. I had to make do with the old Graham Farish corridor coaches based on Maunsell 8'6'' Eastern section Thanet stock. Even to the point of converting the full third to a seven compartment composite (four 1st, three 3rd) by removing a compartment and inserting extra panels to make up the 1st compartment width.
