Captain Kernow
Looking very nice, Mike and get well soon!
I suppose I could change my name, in the fullness of time, but today I'm called Tim!Thanks Nick, appreciated
These 12 coaches were converted from diagram D117 and when the conversion took place this is when the bogie centres were brought in board to 38 ft. The GWR assigned these as A44 and were a push/pull type of auto coach...the drivers compartment at the end of the guards compartment being 3 ft wide!
You’re lucky, I get called all sorts…I suppose I could change my name, in the fullness of time, but today I'm called Tim!![]()
Bertie?You’re lucky, I get called all sorts…
Not as far as I’m aware…Bertie?
I blame the pain killers! Sorry Captain!!I suppose I could change my name, in the fullness of time, but today I'm called Tim!![]()
Liquorice?You’re lucky, I get called all sorts…
Ahem - still is from MetalSmiths 500mm length @ £3.10I've also added the cross bracing on the queen posts, I'd almost run out of 1mm square L angle, last time I bought a load when it was £3 a ten inch length. Not anymore, £7.99 from Squires
Book marked, thanks AdrianAhem - still is from MetalSmiths 500mm length @ £3.10
Metal Materials, Cutting tools Sundries Model Makers Engineering Tools
Tools & materials for the hobbyist. Nickel-silver, brass, plastics, tufnol. Wire, rod, bar, sheet, metal materials, cutting tools, sundriesmetalsmith.co.uk
Isn't it incredible what errors your own photos throw up...missing hinges and a split in the sole bar - all fixed now.
It ran like a sledge - as it's supposed to, keeping the couplings tight. But it kept falling in the water. I think I may have to install some bearings and sort out the clearances between the oil boxes and if I'm going to do that then I may as well go the whole hog and do a proper detail job on the body...which desperately needs weight.Yes Larry. The bogies were moved from 41”6’ to 38”. Also the supports to the queen posts were shortened.Neat coach. There is a lot more detail on the driving end than I realised. I presume the bogie wheelbase was reduced to clear the mechanical push pull linkage. I retained all my brass non-corridors for the layout but sold off the rest.
