It’ll do more than 17 with the ballast you put in it. I hope the baseboards are well supported![]()
Thanks to everyone who provided help, comment and moral support, the debacles with the local planning department have been concluded and we have permission for the extension. The appeal officer was very clear that there were no reasonable grounds to reject, and the original judgement was flawed in matters of fact. A great result if a bit tedious having to go through two applications and an appeal process.
There is now quite a lot of work to be done!
Why cut the plug off Simon ? If the body needs to come off the plug cab be disconnected and the chassis can be removed leaving the decoder in the bunker . Put a 2 pin plug & socket in for the speasker .Now we need to sort out the decoder…
Wheeltapper DCC offer an ESU decoder with a sound project recorded on the remaining 13xx.
First choice is a 21-pin with Adapterplatine, as this allows the platine to be screwed into place which always seems more workmanlike to me, and protects the wiring, etc. - and as Chris appears to have pre-filled the boiler & tanks with something of extreme density, there are few opportunities to use the body!
First, up front between the frames
Possible but will be visible under the boiler, and challenging for the front chassis fixing. And this would be the preferred location for the speaker.
Second, under the bunker
That’s a “No” then.
Third, in the bunker
Mmm, far from ideal.
Fourth, lying down in the bunker
Well, it goes in, but I’m not at all sure that it gains anything from being on the adapterplatine.
That probably suggests an 8-wire decoder without plug will be the rational option, and reluctantly, I think I’ll have to mount it in the bunker. I much prefer the body to be entirely separate if possible. I might be able to arrange a hole in the bunker floor through which the decoder can be fed into the bunker from below.
this…. With the plug cut off…
atb
Fair comment . Ref the last sentence, if you make bridging wires to fit the socket ( assuming the socket is left with the chassis ) you can then run it on DC . Ask me how i know .Hi Paul,
because there isn’t room for the plug & socket and three inches of 8 excess wires all coiled up.
my preferred option whenever I can is to use a 21pin decoder and mounting plate, as the plate can be fixed permanently to the chassis and the wiring fitted to length. No chance to do that here unfortunately.
and if I have to disconnect the decoder I can’t run the loco with the body off, which is useful on occasions.
atb
it’s August Bank Holiday and it’s persisting down.
Chris’ @Pencarrow pannier. The decoders have arrived, so I should get on with installing one. There are really not many other jobs to do, sandboxes, vac pump, brakes, steps, and it would be good to get this finished, particularly as Chris has made some rather nice buildings for his layout, he’ll be wanting a loco at some point. (Note that I got distracted by Templot plug track!)
Thanks all,
John, that rabbithole is not at all helpful
Chris,
how about a nice slate-built North Wales / Gwynedd village pub…? Ty Coch would be prototypical
The rain has not yet stopped, and I’m not going outside and getting my boot (and toes!) wet, so I’m not able to progress the wagons and signals beyond here:
The bending bars are in the garage, attached to the table on which the laser sits. The memory stick has a small cutting file which will be the first experiment in using Trotec ADA for W irons. There’s a small sample of the material below it. I have rather more available.
The big saw and thick brass is out there too, so that’s as far as those bits of project can go for now.
The g-code files are prepared for the Manor coupling & con rods, and Madame is playing tennis tomorrow morning so CNC milling in the lounge will be possible. Not politic at present
And the pannier…
has now got a hole in the bottom of its bunker, through which the decoder will fit, I hope. I shall now have to make an intermediate plate to fit between the frames and the footplate, to pick up on the two threaded holes in the bunker corners. These will fix the cab to the frames, sandwiching the footplate between. The cab steps and sandboxes can then be fitted to this plate.
Ah, good, it fits through t’ole
And better yet,
It’ll hide under a reasonably loaded bunker.
Right, fretsaw, make plate…
