Nick Dunhill
This time we delve back into the neolithic period of history with this Broad Gauge loco. The etches have just been completed by Jeff Ennis for the Broad Gauge Society, and they were supplied with a few castings, a list of the individual panels and a short section of instructions. I suppose this is a test build of sorts. The brief is to build a model of the loco below, dated 1885.
I had a longish chat with Jeff on the phone and got going.
I cut out all the chassis frames and stays, together with the cylinder and motion bracket parts.
I assembled the cylinder, ashpan and crank axle support sections. I decided not to use the rocking beam suspension system Jeff had designed into the kit. I am sure it would have worked well, as I had built a similar system designed into Scorpio's Queen class kit. The need to be able to remove a crank axle necessitated the use of hornblocks, and the frames were modified appropriately. The ashpan side is part of the rocking beams and I cut away the latter.
There is quite a complicated structure to the rear of the cylinders. It supports the bogie and centre section of chassis. Luckily the instructions covered this, but soon ran out!
I was able to make the basic chassis, and all the etchings went together without any issues. I thought I would build the water tank and ashpan to add strength to the structure before adding the hornblocks and wheels.
The water tank went together in a very satisfying way with MOK/F7-style sub millimetre perfection. The firebox/ashpan sides were also soldered to the chassis, and I completed the bottom, front and rear as they were not moving independently of each other any more. It makes the motor and gearbox almost invisible.
The kit has been designed around one of Jeff's foldy-up gearboxes and a nice set of Ultrascale gears. I had a NOS Mashima 1833 which is now part of the drive train. As I have to build inside motion the drive has to be on the rear axle which is inaccessible to all the usual spur gearbox combos. I got the motor to fit with a minimum amount of slitting disc activity, and then realised I had to turn the motor through 90 degrees!
Chop, chop....
You can see I have made a motor mount to locate it all. It runs very well and surprisingly quietly for a worm and gear, and is easily powerful enough for a shortish BG train.
Wheels and inside motion next.
Chop, chop....
