This is an implement wagon (unfitted) so it cannot form a part of Bentall’s exhibition train (a future project). This carried passengers and needs to be fitted throughout. The wagon might find itself pressed into use for other purposes on the railway (e.g. as a match truck), but these uses will be of a secondary nature.
Finishing off the RCH flat wagon . . .
The primer is the new version of Halford’s grey primer. If I hadn’t read some quite critical reviews of this I doubt I would be able to tell the difference. The fumes from the new formula are less pungent and disperse sooner.
I thought the chassis was flat but one W iron has needed shims to keep all four wheels in line. I have my doubts about the long-term stability of a styrene chassis with a wooden floor and no bracing from a body . . . I can only wait and see.
The Slater’s brake parts are moulded in black plastic. I couldn’t really see what I was doing fixing black onto black so I used some spares moulded in grey, these were left over from a rectangular tank wagon.
This was the second model I posted on WT!
The moulding for the brake hangers is rather short and sets the brake shoes about 1.5 mm away from the wheel treads, so I did a cut and shut with the various parts and closed up the gaps. I think this looks better, but really I think brass is better for such intricate assemblies.
The Slater’s coupling hooks are too thick to fit into the slots in the headstocks so I used some etched brass hooks instead.
For the avoidance of doubt, I don’t get on at all well with springs, especially the tiny Slater’s ones. Such springs never seem to have much effect in my short trains so I won’t miss them. The buffer stems and the coupling hooks are set solid in Araldite.
The colouring on the coffee stirrers is Colron wood dye (“English Light Oak”) applied by brush in a really thin coat. I rubbed the side of a soft pencil over this, the graphite leaves a silvery sheen to suggest bare wood starting to weather down.
I have plenty of unfinished models behind me so this time I will leave this as a model of an unfinished wagon. With no superstructure I can try it with some out of gauge loads.
This wagon was supposed to be a filler to keep me busy for a few days between Christmas and New Year. It has taken me another week to get through it. I would have never written this four years ago, but I now find brass so much easier and more satisfying to work with. I am rather glad this model is done.
