4mm Llanfair
LarryG
The Wills kit did one positive thing, it got me thinking about how I would create the illusion of point rodding using metal parts. More 1mm square brass rod has been sent for while other bits will be fabricated from metal so I can solder ~ always my fav method.
The whole rodding assembly needs to be tough with being so close to the track and constant activities of a track rubber. My points are already activated by 1mm square brass rod. Crude but affective.
PeterM
The plastic type of rodding is probably best for the runs under track to avoid shorts. Otherwise I have some nickel silver from Wizard which I’ll use elsewhere when I get round-to/it
LarryG
I had ordered the 1mm square brass before putting my head in gear. Someone said the GWR used round bar for point rodding. Any information on this would be appreciated. :thumbs:
PhilH
Trawsfynydd - 1¼" dia. round bar
Some 60+ years ago I must have had some vague idea of modelling a GWR branch line based on the Bala to Blaenau Ffestiniog Line, and I measured various things on the line (then closed), including point rodding. Fortunately that period was short lived and I had a change of direction, finding far more interesting railway subjects to pursue and model. :)
LarryG
Llanfair was still carrying lots of sheep in 1955 and so the sheep & cattle pens have been doubled in length. Once again, a standard Wills kit was built to suit my needs.
Vinyl grass sheet has been laid to hide a multitude of sins, but it will be hand painted to show wheel track and mud etc. later on. The pens themselves are freshly sprayed and need weathering...
LarryG
I spent the afternoon dismantling the working steering from a plastic bus while attempting to fit it on an EFE Leyland TD1. Disaster, so the TD1 got binned and I set about constructing a renewed history for the Birmingham bus.
Legend says it was a Leyland PD2/12 demonstrator sent to Birmingham in the early 1950's. Birmingham asked for several changes to be made to the specification before placing an order, and this rendered the demonstrator non-standard when hundreds of similar buses were purchased with Crossley, Guy and Daimler engines. It was sold in 1954 to Newtown Motors for a knockdown price. Seen parked at Llanfair station while the crew drank tea in the station café.
Reversing to the setting off point behind the bufferstops. A single decker was normally used, but this decker was substituting for the rail service between Llanfair and Welshpool during upgrading of the branch...
LarryG
A lot of work was going on behind the scenes while waiting for some new acrylic colours to arrive. I would normally avoid acrylic, but i am sick of Humbrol enamel matt paint drying glossy and finding other enamel paints almost solid in their tins since they were last used. Acrylic will be used on scenery but definitely not models. The extended sheep & cattle pens have been bedded in place....
PVA and static grass will hold the pens in position when dry, then I can fit the concrete parts around the track. The brown gates are not what I envisaged, so I might run a dirty black wash over them to represent creosote...
