Hello Martin,
I have read with interest that you were not planning to ballast your railway (post 233, dated 16 January, 2025). To my mind this is a good decision!
Gilbert Thomas did in fact try some experimental ballasting, and the results may be seen in the photographs in Plate V, opposite page 64 in 'Paddington to Seagood'. Elsewhere (ibid., pages 115 - 116), Mr Thomas writes:
'Some day, we promise ourselves, we will ballast the track! A little temporary and experimental ballasting of one section was, indeed, carried out some years ago. It may be seen in the photograph of the "country" station, and[,] though it was not so neatly finished as the permanent thing would be, the illustration will sufficiently show the improved appearance which ballasting produces. Nevertheless, the ballasting of a complicated system is a big (and sticky!) job, and so far we have shirked it'.
It would seem that Gilbert Thomas did not proceed any further with the idea, and perhaps this was just as well. And, as you say, it does look as though ballast was not applied to the Sherwood Section (a line which no-one would call unrailwaylike!). For Gauge 0, ballast would need to be very finely graded, and, if laid 'loose', would be likely to spread everywhere. If glued with PVA or with a similar fixative, the ballast would make it difficult and messy to lift and/or to alter the track itself. Personally I feel that on a vintage layout the unadorned track, such as 'Lowko' or small scale permanent way, has an appeal of its own.
