Mm, well, I did overdo it a little bit, so progress somewhat slowed yesterday. I did watch some bits of the State Funeral - not so much because I particularly wanted to, (although I did feel that I ought to) but more because I didn't have the energy to get out of my chair for very long!
Today has been a little better though.
Having got the right hand, door side half of the front attached to the building, attention turned to the left portion, with the window!
I thought it would be a good idea to attend to some intended modifications while the part remained lying down on a flat surface.
The original square window of clear, but now almost obscure and yellowed acrylic was unusually framed up around the glazing sheet with fairly sturdy, slotted timber, the joints at all four corners were fully tennoned and then the whole assembly was nailed with those horrible, ringed, locking type (I cannot remember what they are called) jobs into the aperture. To make matters worse, the right-hand side was fitted over the door frame, thus directly abutting the closed door and making the width of the shiplap section on the left to the corner notably greater than on the door side! As the glazing could not possibly be replaced without first prying out the entire frame, (in the end I had to completely destroy it with the aid of a hammer and a sharp chisel!) I wanted to replace it with something a great deal less "shed- like" and much more "booking office" in appearance anyway!
I do not have ready access to a portable power saw, so had to resort to the terrible trick of drilling a line of holes and snapping out a section of one plank (seen in the above view) in order to be able to use a conventional hand saw for the rest of the cut.
Great care had to be taken all the way through, as those ageing tongues and grooves are desperately slender and dreadfully fragile!
After lowering the aperture by one plank to improve the overall proportions, I had a spare length to cut into some short sections for a fillet between the window and door frame...
Unfortunately, there is not enough to go the full depth, so I'm short of two bits!
If anyone is puzzled, I have used a couple of slender offcuts from the revised corner post arrangements, as well as the old chopped out window edge support, to act as a plank alignment check.
I am really hoping that I can acquire some fresh, new shiplap planks of a similar enough depth or thickness, and from somewhere - very soon - for necessary repairs to the top and bottom rails of the main structure. If I am lucky, (and I'm not holding my breath) that will mean I can cobble a wee bit more of the original material from elsewhere in order to finish off the line!
Only Goodness yet knows what I'll do if I can't...?!
Pete.
