I’ve half a notion that there’s one in the OPC SR Signalling book by Pryer, but can’t be certain.
Had a flick through both of Pryer's books, no drawing.
Back to thinking about the ground frame. What I'm after is this: Ground frame hut, Norden, Swanage Railway (as conserved in use at Norden on the Swanage Railway).
Looking around for pictures, it seems that Lynton (on the Lynton and Barnstaple) had one of these and there is a book of drawings: Lightmoor Press Books - The Lynton & Barnstaple Railway Measured & Drawn - now I don't need this book (wonderful though it undoubtedly is) but if anyone has a copy and could check that a drawing of the ground frame is present that would be a help. Yes, I know that Kernow also did a resin version and... no.
Failing that, I seem to remember that @phileakins volunteers on the Swanage Railway - can you help, Phil?
Hi Adam
Let me know if you want anything else from the hut - I'll add it to the list of stuff I've promised to do!
My excuse is that I've taken forever assembling a dissertation (or it seems like it) but it's done now. I'll get the camera out.
Phil
because I quite fancy having the station lit by Tilley lamps on hooks, per the S&DJR line across the Levels or the Yeovil - Taunton branch whose minor stops were all lit like that. So not the lamps themselves, but certainly the hooks.
(have you tried 4mm three links in gloom?!)
, let alone 4mm three links!
What style are the Tilley lamps. Could they be fashioned from tiny beads and wire?
EDM models do some very nice dummy bolts, washers and rivets. Just right for corrugated iron:Casting around for something suitably modest to serve as a station building - in LSWR light railway terms, this usually means corrugated iron or concrete. The Fawley branch had some quite elegant (but rather large) Arts and Crafts influenced designs but that's not quite what I had in mind. Then I stumbled across a composite drawing of the structures used on the Basingstoke and Alton Light Railway over on the other channel which at just shy of 40' long and made of wriggly tin fitted the bill nicely. There are some quite good photographs of the structure at Bentworth and Lasham that survived as a coal merchants on ebay which has helped and the current state of play with the carcass of 40 and 60 thou' plastic sheet is below:
I can see that I'm going to have to paint the two-tone interior wall scheme before assembling the front walls...
The box in the waiting room is the ladies loo and the lean to at the end the gents which had a markedly narrow door (2'!) and no window:
My version will be somewhat less decrepit than the state of the real thing below!
Very impressive sir, though mine's bigger than yours!!
