Rob Pulham
Hi Rob. Very nice. As its a tad early for my era and i dont know anything about horse boxes
what livery will it be?
Thanks Rob, I planned to finish it in lined LMS livery but I have been struggling to get any running numbers for them in LMS days. It seems that the S&D retained it's livery until 1930 so I was resigned to painting it ultramarine blue (now steady on boys, don't get too excited
) and spending £20 on a sheet of HMRS transfers that I would only ever use a few of.But by good fortune and timing for your enquiry Rob, I had a reply this morning from a gent in the S&D section of the HMRS who has let me have LMS running numbers for a few of these horseboxes and by coincidence for the one that I have a B&W photo of that I have been using for reference. So LMS lined livery it will be. I need to get my finger out and build the Midland one that I have so I can paint them both together.
You are getting some very nice results Rob...........the Aldi gas torch I showed you has proved a real bargain too
Cheers Phill, what I like about the microflame is that you can get away with the smallest amount of solder and get it to run into the joint by capillary action, This leaves virtually no solder to clean up, just a bit of discolouration of the brass which cleans up with a plastic pan shiner.
. As you say it's a pity the doors are not seperate parts
. You could have used some of my really bad Yorkshire/Saxon language (as I used tonight
) whilst trying to get the hinges to work.
when a couple of my hinges flew off into the carpet monster,
never to be seen again until they rattle around in the vacuum
