Ok, final checked all the major parts fitting, the last two fabricated parts were the motion bracket and rear brake hanger bracket and needed to check the splasher lengths, the leading one is 29.4 mm long and in Autocad the rear wall arch is 29.4 mm long, yet the splasher when fitted is a good 1.5 mm too short
so it's extended on the artwork, easier to cut back than being too short.
The motion bracket made up nicely, except for my bodging, the second one should be much neater. I try to alternate left and right side of the loco when building the first of duplicate parts, that way all the error finding crap work isn't on one side
The rear brake hanger bracket is tight, there's still the half etch footplate bracket to attach to it and it just clears the wheel rim by a few thou.
I'd of preferred full etch footplate bracket but that'd mean pushing the whole rear end back by 0.4 mm, which bearing in mind affects a dozen pieces, is not worth the hassle this late in the day. The alternative and the solution I'll probably use, trim 0. 25 mm off the wheel rim if I need more clearance, but as mentioned it does presently clear the wheel with out any alterations.
Some front end images of motion bracket and splashers etc.
In the above one can see the six holes in the frame work aside the bogie stay, they should be rivets, Captain cock and his merry band passed that way
You can also see the nick in the cylinder rear lower to clear the rear bogie wheel, al la prototype, should be plenty of clearance in OF also seen the fixings etched in the wrapper for the drain cocks.
And with front driver removed, more to show the hidden splasher in the motion bracket, it also forms part of the structure and adds strength to the whole assembly, real and model. The eagle eyed will have spotted a recess inside the frames just behind the front axle, where the stay with no name has dropped out
Finally the rear brake hanger bracket, a small fold up affair.
It really is very close in there, about 0.4 mm clearance.
Note horrid slot in the inner frame extensions for the rear pony stay, that'll need filling before spraying and it all needs a thoroughly good clean right now.
In other news, I've finally worked out why my wheels start to tarnish and rust as soon as I clean them, like a right berk I'm using a fibre brush to clean them, the same one that I use to clean the model, which has invariably picked up some flux impregnated
, so, I'm cleaning it as well as applying a fine layer of flux all over it
Right back to checking all the art work ready for MkII to be sent off early next week, then the left side of the loco will be finished as well as all the other sundries.
Enjoy.
