Ok moving swiftly on, the first thing I need is a large 'flat' piece of brass for the footplate.normally I'd just do this next step behind the scenes but with all the recent chat about rolling bars I thought I'd expand a bit more on this.
Brass is usually shipped in coils, when you buy it from where ever they either flatten it or it is flattened by whoever supplies them, either way since it has been coiled and may well have been coiled warm off the press, or even the fact that is is rolled tightly, will generate heat and give the brass a natural bias to coiling, sometimes when re-heated with a soldering iron.
Anyway, needing a piece just over 320mm long means that the standard stock of A4 sheets will not suffice, so out comes the reserve from under the desk. I am fortunate that my 1:1 job requires working with this stuff on a reasonably regular occurrence (motor & gearbox bed shimming), and after big jobs there is always some left over
This was the smallest piece I could find, no point being greedy
First job is to scribe the cut mark and use a skrawker to cut through enough so that you can easily bend a piece off. The flattening process will leave wastage so needing 320mm I cut off 350mm
Mmmm Banana
Still, not a problem, out with the rollers and stuff it in upside down, we're going to flatten, or more correctly reverse roll.
The side with the tape marks is the outside and I simply adjust the top roller so that I can easily feed the piece through with it's natural curl.
Having done that I simply apply top roller pressure a bit at a time and hey presto the piece will begin to flatten, however, I carry on and apply even more pressure to make a complete reverse curl, now I know that the piece has been curled equally both ways and that should ease the stresses in the material.
Having reversed the curl I then slacken the top roller off, flip the material over and start the process again, but this time as it gets near to being flat I stop adding pressure, eventually it will become quite flat.
At this stage I flip the material over and run it through again without adjusting the top roller, you will find that one way it'll come out flat, the other way it'll curl....back to it's rolled state.... so I just keep going over and over until it rolls flat both ways, then your pretty sure it's stress free and ready for use. As this is just a test piece I just ran it through half a dozen times or so, but if it was something that had to be really flat like frames or footplates I'd run it through twenty or so times.
I probably don't have to go through all this malarky but I find it works for me and I usually have a nice flat and stable piece of material.
You can see that each end has a little kick in it, you can work this out, but I always cut this bit off as it hasn't been through the rollers fully as its the bit that drops between the rollers at the start and finish. You could use a backing material but trimming 15mm off each end is easier, it wont go to waste as it can be used for smaller parts of the model.
Y'all may already know all this, so apologies for the egg sucking exercise
Next up a rough cut of the basic footplate shape and trimming to fit the chassis and body.
