4mm West Halton Sidings - Bristol VRT
James
Would the Ratio GWR signal box windows fit? I've used them for all sorts of non GWR applications, though I have to admit that in some cases I've fudged the window opening measurements to suit. No-one has picked me up on this, yet.
It won't unfortunately as the cabins had some larger windows and various different sizes of windows.
They're lovely buildings though :)
James
I've temporarily given up with signal box windows so having a little change. I used to do lots of things with buses but not so much in recent years. Yorkshire Dave's recent post got me thinking.
Post in thread 'Yorky D's Küchentisch: Head towards....' Yorky D's Küchentisch: Head towards....
I love how buses can tell the observer where and when a layout is set, so this seems like a good subject for North Lincolnshire.
A Series 3 EFE ECW Bristol VRT was stripped down - beneath typical diecast manufacturer paint lies lovely tooling.
In white ready for the green and yellow. Masking has begun.
The plan is to fit new glazing and replacement vents from MH Models but now available here -http://www.paragonkits.com/details.htm
It'll be interesting to see the VRT progress. I also see you have cut out the destination box.
The only thing I would have also done prior to priming is add the missing panel lines to the lower and upper decks and the central cantrail - which I do with car headlight repair tape cut into thin strips.
The panel lines are missing from a lot of EFE models which to me jars - apart from the recently retooled Routemasters. I suspect it's more than likely to do with fleet name and advertisement printing.
James
I gave the panel lines some thought but decided to leave everything as it was on this one, mainly in case I couldn't match the appearance of the cast panel lines and beading.
EFE can be quite frustrating with panel lines and trims, especially on 50s and 60s coaches where the elaborate chrome trim is merely printed. I've always liked white metal kits for vehicles like these where you can scrape the paint off the trim and polish it and it gives you a wonderful look of chrome.
The green has now been applied, Humbrol 131 is actually a pretty close match to the green Roadcar used at this time. Somebody on a Lincolnshire Roadcar Facebook group advise me of the ral code for the green and the sample I found was very close to the Humbrol colour - for scale colour I think it's spot on!
I'm going to leave the green to fully hardened for a few days and then I will apply the yellow.
I've been making my own transfers for this and ECW Leyland Olympian which will use a Tower Models/Peco kit as the basis. It'll be one of the dual purpose vehicles which was used on the 350 Scunthorpe to Hull services, the interior is going to be completely replaced along with the glazing.
I did add panel lines to a United Counties series II VRT.
The main objective of this one was to recreate the distinctive ECW ivory/cream window rubbers.
Which was achieved with an AK Interactive paint brush pen. The silver Sharpie is used for the moulded sliding window and hopper window frames.
James
The panel lines do really add to the appearance - very neatly done. Maybe for the next EFE conversion?
The window rubbers look great - I was wondering about the AK pens for adding the rubbers to models.
Looks like a transfer caboose in this state :) .
In respect of the decals and if the loco body is white one solution is to print the decals on white decal sheet and apply to the entire cab side and cut out the window once set.
With a clear decal sheet you could always overlay a second set of decals to strengthen the decal colours.
James
I hadn't thought of that, that's certainly worth the try.
The Janus is fine looking faded because the real one was in an absolute state in the summer of 92! @Tappa gave me a number of photos taken around this time on the steelworks and as you might expect most of the locos around the filthy.
Next task will be trying to get a decoder and stay alive in the loco. I haven't exactly left a lot of room for it all, so I think it will have to go between the frames and the decodes will be stuck to the underside of the motor.
I think I might have another go with the transverse though as they're not as good as I would like but I have printed about eight versions of them so lots to try!
James
In other news the VR now has its yellow paint on, there's a little bit of tidying up here and for the most part I'm quite pleased. The doors need to be green I figured it would be easier to paint those after the mainly colours were applied and save on some very complex masking.
The buses on unmistakeably Lincolnshire Roadcar :)
ColPeake
Member
That's coming on really well. It brings back a few memories, not only did Roadcar have a few tendered routes into North Nottinghamshire at one stage, one of our local independent operators bought a job-lot of ex-Traction group VRs for school contracts and ran them in as-acquired liveries for a while, including Roadcar!
By the way I've always understood that initially (and maybe always) the green in the post-deregulation Roadcar livery was actually NBC leaf green, but with the yellow and white the effect was very different. They were not alone, East Midland, our ex-NBC operator, also used NBC green in their post-deregulation two-tone green and cream livery. Ironically under Stagecoach our buses are now legally registered as Lincolnshire Roadcar...
Colin
alastairq
Of all the different deckers that I have driven, the VR is my favourite and even better when running on propane gas.
Me too...On top of them all, I by far preferred the Gardner engined VRs.. having also used [in anger] the Leyland engined versions acquired by EYMS. The Gardner engines were far better for the slogging power an urban decker needed to have...The Leyland engines were 'screamers' in comparison....No good for overtaking cyclists out in the countryside, either. I had experience also of the 'white window rubbered' Gardner engined VRs belonging to...as one time, United Auto...I remember watching one, parked, [likely left in gear with handbrake applied?]...and observing the rear wheel nuts banging back & forth as the wheel stud holes gradually became elongated. Open toppers included as well.
The downside of the VR for me, being very long of leg...were the cast steel [iron, more likely?? :) ] gear lever and horn/light switch pods either side of the steering column...adjustable only with a spanner, when no one ws looking...otherwise I was stuck with driving around very splay-legged.
Cab heating was a bit hit n miss as well....so very cold steel control pods, and very cold knees, has left me with issue now I'm old.
