I'm going to wait until tomorrow before doing lettering, to let the varnish harden. It occurred to me it would be good to be able to position the chocks correctly, to them do the securing pins, before weathering. This means knowing where the wheels of the planned load will come.
I dug this out of the Cupboard of Possibilities - the planned load:
The first step is to build up the main body - this is a single etched part, which folds to make the rectangular shape:
Looks okay, doesn't it?
Except - the fold lines are partly half etched, and partly etched through, in a 'dotted line' pattern. You can see an unfolded line at the top, and a folded and soldered one at the bottom of the side:
So you get a weird dotted edge. Am I expected to fill that? How? Or file it to an unprototypical chamfer?
The same on the corners:
And the back corner:
And what are those chain-dotted lines running across the doors?
While we are at it - there's a huge gap in the two panels that make up the front:
The instructions say "if there's a gap, fill it with a piece of wire". If? IF???? Clearly the designer knew perfectly well there would be a gap, and instead of modifying the artwork, wrote a line in the instructions.
And one other thing - the foot steps fold from an inner end and go through slots in the outer face of the end - a familiar way of designing these:
Seriously - how am I expected to fill all that space around the steps and make a decent job of it?
So - plan B. I'll use the supplied castings and perhaps one or two of the etched parts, but do the main build from plasticard. It's pretty much a box, with the slight complication of the wheel arches, but really a straightforward thing to make in styrene. I can use the kit etches as a template.
Another £35 badly spent!
Anyway, I'm slowly regaining my equanimity, and there are many worse things in the world than a shoddy kit, especially right now, so onwards and upwards.
I'll make enough of the kit to work out where the wheels will land on the wagon, and stick it back in the cupboard for another day.
It seems the Serpent has allies....
Nick.
