What follows won't affect Giles but may help folk with weedier lasers or none
Discarded packaging is a good 'free' source of tinplate, though it's fair to say that biscuit tins and oil cans are generally more useful than bean tins or cat-food cans
Containers are generally lacquered internally and often painted externally. It's not ideal, yet when I had access to a school laser (before Covid), I took full advantage of those coatings as Resist layers.
[In a nutshell, I lasered part outlines into the painted side, then etched through the metal until I could see light through the lines. At that point the varnish conveniently held the whole sheet together, avoiding small parts escaping. Parts needing paint could simply be pinged from the sheet, degreased, and glued to the model. But wherever I needed bare metal, I struggled to remove food-grade paint, which the usual chemical strippers won't touch.
This method doesn't even depend on access to a laser: simply scribing around a template with a sharp steel point has the same effect.]
Maybe worth mentioning that some metallic food packaging is aluminium alloy.
The base of a traditional 'roll-top' sardine tine is slightly dished, which means that, for suitably small components, the upturned tin forms its own tiny etchant bath, This saves on the quantity of nasty liquid for disposal, and makes it easier to put in landfill rather than waste-water.
David 1/2d
ex Metal Box Company
