Prototype G1 Western
D1054
Hi,
Just wondering if any more news ?
Hi, Sorry I've been away from the Thunder a while, but hope to be around more now, and back on the modelling front. Yes, there are now 5 x 1/32 Scale prototype Westerns in build, and seven in G1. I've been trying to get a traction motor solution, but those damn inside frames on Wizzo's don't leave right lot of space!
David Halfpenny
quote[those damn inside frames on Wizzo's don't leave right lot of space!]/quote
Too Right! Designed for Cardan shafts.
So may I ask:
- what clearance between frames have you got?
- given that G1MRA Standard is costing you 2mm you can't afford, what clearance might you have, were you to slim-down the frames as brutally as your aesthetic conscience will allow?
- and what wheelbase, please ?
David 1/2d
David Halfpenny
D1054
Would this sort of power bogie help?
These are for a Deltic, and with six axle-hung gear-motors in total, it hauls an eye-wateringly long train at 100mph.
The "N20" type gearmotors are nominally 1 200rpm at 12V geared 1:1 to the axles. The plastic cases keep the muck out. Power is via radio-controlled PWM from a 12V battery.
In this configuration, the wheelsets have outside bearing, fully-equalised in the Bettendorf rocker-bogie manner.​
By using narrower pinions, maybe you could squeeze in inside bearings and rocker bars?
Like this schematic (for a Mars-Rover):​
(Equalising the axle-loads is well worthwhile, because you neither want to stall nor slip any of the motors.)
Bogie and Photo Peter Jackman.
To find out more, infiltrate the Gauge One 3D Circle:
GaugeOne3DCircle groups.io Group
(3D printing is not Of the Essence: just a handy way to experiment - heck, even Peter's wheels are printed!)
D1054
Hi David, that's most helpful, and an interesting development which I must look at more closely. I'm busy turning 1/32nd wheels for the Wizzos at present so sorry if I'm slow to respond. I am using MSC, ABC and Appletree motor/gearboxes in the prototypes, but really want to crack a traction motor solution if at all possible. Easy in the G3 EM1s, but the G1 and 1/32nd Western is presenting a few challenges...
Perhaps you'd be available for a chat sometime?
David Halfpenny
Sure, though not this minute :)
If you know Apple Tree, you'll probably know Tim's drumming-up custom for a G1 version of his traction motor. He'll tell you whether he can do inside frames.
But the essence of Tim's is the 10:1 gearing, which keeps the speed down to maybe 50mph.
The me as a Midland man, that seems a sensible speed for a clapped-out Western, but True Fans might want the full 90mph originally specified.​
I doubt a FosMotor could do inside frames on G1MRA Standard track, though it might just in G1MRA Fine.
David
D1054
#1.jpg Hi All, Just to update on the G1 prototype which I'm finishing over the week or so before it's off to its new owner. Then on the the next one - in 1/32nd.
D1054
That does look very nice ! A lot of work so well done to get it that far. Kits later ?
Robert
Hi Robert,
I'm hopefully finishing the build today, and then I'm going to put parts together for another 7 off. in Gauge 1 and 7 off. in 1/32nd. I also have two in Gauge 3 which people have asked for. They're certainly not "standard" kits, but will come together nicely if you put some time and effort in.... :)
D1054
Well, not quite finished, but Enterprise was back in the paintshop after driver and detail installed, cab roofs fitted, rain guards attached, bogie spring guards fitted, OHLEs applied, then roof sprayed to blend.... just speedo, sandpipes and roof eyelets (not sure how best to do these... any ideas?), and final weathering... then on the 1/32nd scale version.W1.jpg W2.jpg
Thirtysecond
David
My Fred Phipps Warship uses a FosMotor on each axle. The only requirement was to significantly turn down the thickness of the bearings in the bogie frames to allow room for the unit . I was initially worried about wear with the reduced bearing surface. But actually, with careful cleaning and lubrication, it has never been a problem and it must be 15 years old now. If you have seen it running you will know it is very smooth and can maintain scale speeds with ease.
David Halfpenny
So have you slipped metal bogie frames in between the Fosmotor frames and the wheels, Derek?
Or something more sophisticated?​
Thirtysecond
No that's it exactly. But the bearings when turned down to fit are not much thicker than the frames!! I seem to remember that it was made easier because I used Mark Wood wheels on telescopic axles. Not sure if he does those axles any more.
Thirtysecond
... just speedo, sandpipes and roof eyelets (not sure how best to do these... any ideas?), View attachment 123204 View attachment 123205
Two possibilities.
  • Fred Phipps supplied a casting sprue of roof eyelets which I used on the Warship. If you look carefully at the above picture you can just see them. Fred always seems willing to supply castings and other parts to help people out so might be worth contacting.
  • 1/32" cotter pins if you can still get them. I bought a gross of them donkey's years ago. They've been really useful but only have about 4 left now! Obviously they are not quite right as they are not perfectly circular . Better than nothing though.
D1054
Hi, many thanks for this. I met with Steve Foster and I do have a set of frames and motors from him, but I can't quite get the fit, so I'm cutting my own frames to do this. It'll be a tight squeeze, but I think there's just enough room to make it work. I'll post when I'm something meaningful to show. Many thanks again.
D1054
Two possibilities.
  1. View attachment 123580
Thanks for these - ordered! :)
