Old Buffer
Superb modelling as ever, puts mine to shame.
Alan
Alan
I must have been intuition, when I was taking the photo's I thought to myself I bet Graham asks about chains for the caps - uncanny!Why me?
Sorry I missed this yesterday - I was too busy thinking, I knew you would ask that!Which kind of means that given your modelling period then you must be representing a Class B tank.
) built it as a Class A. So it has languished in primer for over a year while I I was taking the photo's I thought to myself I bet Graham asks about chains for the caps - uncanny!
So a bit more thinking on that one is required.
Very nice, hope this idea works as I shall pinch same for our tank wagon.
What material have you used for the eye-bolt?
.Splendid work yet again Rob, hope you can make it to Ponty on Sunday. If you can could you bring one of the anchor pins with you for me to have a good look at, I am in the process of scratching some tanks and the pins may be what I am looking for.
Alan
Hi Rob,
brilliant work - hope that your eyes take the starin as well.![]()
. It might be small but I find it very therapeutic, it completely stops me thinking of work.
So pondering this I diverted my attention to the other end of the chain and started by threading one of the rings that I had made initially through the other end of the chain which I then attempted to solder to the tube adjacent to the cap. Not much doing with this either. I have a really fine pair of stainless steel tweezers which I was using to hold the ring and chain, I gave up after soldering them to the chain for the 4th time.
Hi Guys
Graham, I think this is the picture you are referring to....
It's made from 2 strands of soft brass wire, about .35mm diameter, just wound tightly together. One end of the both strands is fed into a chuck, the other held in a pair of pliers, and the chuck twisted by hand until the required tightness of the 'links' is achived. the eye is farly easily fooled into thinking you're looking at separate links.
