At the Kempton show I made an unwise purchase of a 4031 Achilles class 4-2-2 with tender. It was three-rail coarse scale but the paint job looked ok, so I thought, “that’ll be a project”.
on closer inspection, the build is not too bad but the paint is not as nice as I first thought, so it’ll be “one of those jobs”, and it’ll involve some more experimentation…
firstly, wheels. They’re cast iron, and now approximate an 0F profile. I was turning them when my lathe motor (suppression capacitor) exploded a few weeks back…
as you can see, I have bushed the driving wheels with Tufnol, and I will bore that to suit the axle in due course.
The tender has now been converted to split axles, using 2mm glass fibre rod and normal (ie NOT 5-minute) epoxy. The plastic blocks are 3DP and they hold the axle halves concentric and at the correct BTB.
I have also printed the first iteration of the inside frames for the tender, which as you can see, have brass axle bearings. These will be electrically connected and used as the pickups.
it’s equalised - there is a bogie supporting the front and central axles, which is free to rock in pitch about the crossbeam just abaft the front axle. The longitudinal beam connecting the axle supports is designed to flex in torsion so the axles can accommodate any cross-wind in the track. The bogie can also roll relative to the fixed rear asleep.
Iteration 1 works, but just not quite as well as I’d like. Iteration 2 will have a bit more freedom in pitch for the bogie, and the torsion beam will be a little less stiff. I’ll include mountings for the scoop and brakes, and lugs to screw the footplate/body to it. I’ll print it this week, and then the tender can be on its wheels. The brakes that I did for the Manor tender will fit this one too.
All the printing so far has been FDM on one of the Bambu printers at the office.
Then things get more challenging…
