This takes about 30 minutes to cut out all the parts …
It does. Once the brickpaper goes on, you won't see that joint......
Only joking.
Any chance the laser can do a few spalled bricks? Older brickwork always has one or two.
Phil,
I saw some very similar slates this morning... cut by laser just as you have shown... in 4mm for a 1865 GER station building.
Any connection between the two?
Hello brush Type 4,
a small note on your slates, in the old days the roofing slates tended to start with a slate that was 1 1/2 X the width of the row above or below it. So if row one started with a slate that was 18" wide the one above it would be 27" wide and so on. This worked on gable ends, but if you came to a valley or a step in the roof the slates would have to be cut to suit.
In latter days with the new mass produced "slates" these are normally cut to half the width at the start of a row.
The other point is that the gaps look a bit wide between the slates, most of the time the gap was less that 1/4". But it's hard to judge on your photo as there is no scale to go from.
Glad that your getting some time to have a go with the new M/C.
The above points are only to try and help and in no way meant as a criticism of your work.
I hope that the burn is healing well.
OzzyO.
Version 4 for such an exquisite prototype? I would not worry... if you go back through the late Cynric's thread on building a model of a brick building you will find that Cynric had several attempts to get an acceptable corner joint.So to version 4....
No criticism taken.
I didn't know about the extra width slates, I had assumed that the slates would have been reduced in size to get the overlap required for each row. I hadn't realised that was a relatively modern practice. Do you know when this practice would have lasted until?
