The large bits of the boiler cradle are there.... it was an experience... as in the drawing above, I took a big risk with laser cutting the valance under the edge of the running plates. These are 0.8mm deep, with teeny tongues....
The first effort resulted in a thin charred mass in curly pieces, after which I remembered that I had bought a sheet vise for this sort of job. This is a vise whose jaws are each horizontal clamps which grip the edge of a small sheet, and the handle that tightens the vise moves the jaws further apart rather than closer together, thus keeping the sheet of metal unter tension whilst it is being cut.
This was more successful, but required careful adjustment of 'passes' to the minimum to do the job in order to get a successful result, which I eventually did.
I used the same settings in the vise to cut the running plates as well.
The first time I've used that vise, and we'll worth it....
Those really fine tongues were a real fiddle to assemble, as my eyesight even with magnifiers wasn't really up to it. It would have been fire in 7mm though.
I couldn't risk silver-soldering this, as the distortion would have been very significant, so it was all soft soldered. The principle of long tabs and twisting them works very well though. I think I might have seen it before - does MOK use this?
