this photo from the Kitten Engineering site shows the detail that unfortunately the GWR Modelling doesn’t. But of course, it’s a case of modelling a model, with the risk of perpetuating a mistake.
Simon T’s note confirms what I had surmised, and my investigation of the F7 site had revealed, that the dome has a rivetted rim. And in answer to Simon’s other point, yes, the flange provided is a bit thick 0.48mm scales at just less than 7/8”.
thanks also to Phil, Kev & David. It’s quite obvious that I didn’t anneal the sheet to any significant extent. I probably should have been braver. Being smart after the event, it would have been very easy to put the etch on a bit of brass, scribe round it and create the opportunity to make a duplicate if I’d bu66ered it up.
So, I have some choices. It obviously should have rivets around the dome, and maybe around the filler too.
I can use the kit etch as is, though I think we all know that’s not happening.
I can add a ring of rivets around the said etch, two possible approaches, set up the GW rivetter and X-Y the rivets, or set up a guide and use the edge of the etch, and the previous rivet as the guide to place each rivet.
I could, but I’m not going to, create a new etch with the rivets etched in, or holes on the reverse to guide them being pressed.
I can also draw it up in CAD and 3D print a dome with a rivetted flange, which would be easy to draw, how well such a thin flange (say 0.2917 mm - scale half inch) would print is a question.
Or draw it in CAD, print & stick paper to a bit of thinner brass and rivet & then cut out.
Meanwhile, I‘ve been doing the steps.
Fresh out of the ultrasonic. I see one of the straps has pinged off. Will fix that tomorrow.
S
